COS+ pin in repeater
asked Jan 19,2024
Hi Enginee'r. Where I should to connect COS+ pin? About your Carrier Operated Squelch. Thanks
Piezo PCB motor refrence design.
Payment by wechat
PCB Stiffeners material specs
variable state filter pcb
Jack Durie
