This adapter is design for a 87C510 DIP28 eprom, but i need the same adapter for a 87PC110 PCC32 eprom !Do you have this adapter or can you make it ?It's the same converter (74HCT573), with same p...
If it's possible to control the power output of a 12V/150W heating element using some sort of buck converter circuit. It should step down the 12V input to various voltages required to vary the out...
Banco de energía con super condensadoresInversor de corriente de 12v y 24v a 110 y 220v con bobina toroidalControlador de energía de vehículo eléctrico Aire acondicionado con celdas de peltier y ...
Hi, I have a beefy 12V 60A output buck converter which is advertised as having "Short Circuit Protection", I was wondering if I can use a current limiting circuit to essentially make this su...
I have a bunch of dead TV line transformers that I salvaged the ferrite core from. Typically these run around 20 to 40kHz or so.If I remove the air gap and use these cores as traditional high frequenc...
