2816
[PCB Prototype]
Minimum distance between traces for 250/400VDC
HelloWhat is the minimum distance between traces/polygons on your PCBs for voltages like 250V or 400V? is 66 mils/1.7mm enough, it could be less, or more?My current desing:
isolation
400v
250v
PCB
High-voltage
Jun 01,2018
Jan Kotarski
What is the length of data collected before/after the trigger for the Logic Analyzer LA104?
I asked a quote to JLCCNC
Peter de Vroomen
gokul kb
Share to Vkontakte
