[Others] How to read a 5V ratiometric sensor using a 1.1V fixed vref ADC?
The ACS712 outputs a voltage from 0-5V and the ESP32 ADC reads from 0 to 3.3V using 1.1V as vref. There is a voltage divider already to reduce the 5V to 3.3 range.The problem is: voltage drops on the ...
[Others] "Output Frequency" on a DC switching power supply means the switching frequency of the power supply?
Hi all. The output frequency of this power supply is 20-100kHz. Since its DC out, which would be 0Hz, am I correct to assume that the 20-100kHz would be caused by the switching. So I could in theory u...
[PCB Prototype] hi ..do u have any Megasquirt MS2 bare pcb?
[Others] Can I run a Passive Speaker without an amplifier?
Can I connect a 0.5W Speaker direct to an input (Raspberry pi in my case) and expect it to be as loud as a let's say a phone speaker? Will a very small speaker work directly from an input? If not ...
  • answered Oct 23,2020
[Others] Is there any way to fix it?
Hi all, my mini USB connector somehow broke off the board and has been rattling around its casing, I opened it up and found where its supposed to be connected, is this saveable? could I just solder th...
[PCB Prototype] Dimensity 1000 soc.
Hello, I was wondering if it would be possible to have the Dimensity 1000 system on chip preinstalled to a pcb. I have not seen an option for it and I don't have the time to source the chips and s...
[Others] How to quickly reading GPIO pin LOW/HIGH directly?
I'm expecting to see the state of a pin that I'm reading to pull low for maybe 50 us and then back up to high. The original code running on an UNO/Nano code looks about like this:while ((...
[Others] Relay Output Problem
I'm doing a Sanitiser dispenser with an Ultrasonic Sensor. For every alternate sensing of the hand, I'm getting a brief disturbance signal from the relay. It goes on for a few milliseconds and...
  • answered Oct 15,2020
1 ... 93 94 95 96 97 98 99 100 101 102 103 ...
