[Others] The difference between PMSM and BLDC speed control
The speed of the PMSM is controlled by varying the frequency of the three phase signals that go to the motor windings, but the BLDC motor’s speed is controlled by varying the voltage amplitude. Why is...
  • answered Oct 15,2020
    by Kemio
[PCB Prototype] bill of materials
do you have a list of components needed
[PCB Assembly] How to replace this USB Type B connector?
The pins have came off from the connector and stuck to the board. Do I simply clean it off using braid, wipe it using alcohol + brush then use a flux pen. Thanks
[PCB Prototype] How to check net antenna for vias not connected to other layers. I use Altium.
I have some vias placed on fills and regions, but the vias themselves are not connected to anything on the other layers. I was expecting that Altium's net antenna rule will show net antenna errors...
[Others] Question on Differential Signaling Pull-up/Pull-down Resistors
For an electronics project I have to implement a differential signaling mode for transmitting data. I'm planning on using some sort of differential driver and receiver IC. Now I was wondering if t...
[Others] How to prevent cables from disconnecting from the screw terminals in a relay module
I'm controlling a lamp with a relay module but I'm worried about the cables disconnecting since I'm working with mains electricity and the cables are very easy to disconnect once screwed t...
  • answered Oct 12,2020
[PCB Prototype] Amiga 1200 Expansion Module V5
Do you have an english bom?
[Others] How can I connect to this EEPROM to read it?
Not confident in my ability to de/resolder it (also don't want heat to destroy it) and SMD probes can't grab the tiny pins.
1 ... 94 95 96 97 98 99 100 101 102 103 104 ...
