307
"Output Frequency" on a DC switching power supply means the switching frequency of the power supply?
Hi all. The output frequency of this power supply is 20-100kHz. Since its DC out, which would be 0Hz, am I correct to assume that the 20-100kHz would be caused by the switching. So I could in theory u...
low-pass-LC-filter
DC-switching-power-supply
Output-Frequency
Oct 27,2020
Dennis Farquhar
W37275CCSH52 Ruler
