823
Micro Via cost
How much does using microvia in my board design at to the manufacturing cost?I don't see micro via as an option in the instant quote process.My board is 6 layers, standard 10cm x 20cm.
6-Layers
Standard-PCB
Micro-Via
Nov 30,2020
I asked a quote to JLCCNC
Peter de Vroomen
gokul kb
