296
What would be the additional resistance for the pads and tracks if a resistor of 0 ohm is fitted to a PCB?
resistor-of-0-ohm
additional-resistance
Oct 29,2020
Paul H
317
Do turns in a wire or PCB trace create additional resistance over the same length going straight?
wire-or-PCB-trace
Aug 14,2020
Ardumani
W37275CCSH52 Ruler
