419
Some trouble with Opamp circuit
I am buidling this circuit to amplify a signal from a analog sensor. But for some reason, when I build the circuit on a breadboard I get 0v on the output of U1. The output of U2 works fine, so there i...
analog-sensor
amplify-a-signal
Opamp-circuit
Nov 16,2020
Riley Gunn
W37275CCSH52 Ruler
