Hey guys! I'm making a digital power logger and I was wondering if I should add a linear regulator after a switch-mode converter to make the signal less noisy and more stable or should I stick to ...
As far now, the highest voltage I ever seen a boost converter converting is 90V. What stops a boost converter from generating thousand or million of volts?
