I bought the DM-2 PCB, the boards arrived, but I don't know the electronic components and where to place them. Is there a Bill of Materials (BOM) available? Thank you.EDIT.I wrote the BOM from schemat...
Hi, Hoping to get some guidance with a BGA component (LM3533) with 0.4mm pitch. In terms of routing and PCBWay capabilities is there any recommendation.Currently I got it wired via image 1. Diame...
I would like to get a soap mould printed. Can you print it in PETG? If not, can you recommend which of your available options would be most suitable? The final product needs to handle strongly alkalin...
Hello, I found a few different projects from your site that I would be interested in purchasing - the boards along with the assembly. I'm a little confused though about the entire process. Every proje...
Hi Edoardo. The Gotek PCBs that you list in PCBWay are part of an open source project or are your design? I would like to modify the PCB to suit my particular needs but I can't find the project. If it...
