[PCB Prototype] Solder paste dispenser
Hi where can fiend the code
[PCB Prototype] About the Star pointer
Sorry, I am a bit confused, does the star pointer come completely disassembled? Do I buy the boards and components to assemble it?I am from Brazil, can I make this purchase?
[PCB Prototype] Request for Preferred Layer Stack-Up and Material Lead Time (FR408HR)
Dear Sirs, We are currently in the advanced design phase of a PCB project and are evaluating manufacturing and assembly options. We are considering using your services for both fabrication and as...
[PCB Prototype] Rogers 4350B Hybrid-Layer Stackup
Hello, I'd like to know if it were possible to manufacture a 4-layer hybrid layer using the same stackup as in https://www.multi-circuit-boards.eu/fileadmin/pdf/leiterplatten_lagenaufbau/Multi-CB_Defi...
[PCB Prototype] howcan i get the firmware for the Open EIT board so can eny one help
dear sirhowcan i get the firmware for the Open EIT board so can eny one help
[PCB Prototype] UL registration for Flex PCB
Hi, do you have a UL 94V-0 or similar registration for your flex PCBs? If so is it limited to a particular configuration? Could you provide the registration number. Many thanks.Ed
[Others] How to use *.kicad_pcb files.
I had to re-install KiCad and lost all of my projects. I've downloaded all of the boards I've ordered. I've not able to use those files in KiCad or PCBnew. In PCBnew, the file selector is *.kicad_pcb,...
[Components] capacitors question
in electronic circuit Coupling capacitors are used in series to allow only high-frequency signals to pass to the system load, as in the following image. Decoupling capacitors, also known as bypass cap...
0answers
[PCB Prototype] The device is not recognized by windows.
I'm having a similar problem. I've built a HOD2Ami v2 based on an STM32F105. I've used 0 ohm resistors for VCAp1 and VCAP2. With PA9 on 2-3, I always get the same message: No USB device recognized: Th...
0answers
[PCB Prototype] bus bar for 105 ah eve cell in 8s2p 24v configuration
hello, I was just wondering if you could design a busbar/kit for a 24v eve 105ah LF 8s2p configuration? I currently have the eve cells with my own copper bus bars that didn't turn outs great due to th...
1 2 3 4 5 6 7 8 9 10 11 12 ...
