5
2754
[PCB Design]
Best way to make a break-off section of PCB
I want to make a PCB as one design, but with a part as a 'break-off' section - see the picture with the large slot near the top of the board. The board measures about 130 x 100mm overall.Is th...
PCB-manufacture
PCB-Slot
Jan 25,2022
mehmetalidag
Piezo PCB motor refrence design.
Payment by wechat
PCB Stiffeners material specs
variable state filter pcb
Jack Durie
