what is the best 3d printing material for fine details. like on a minifigure?
asked Aug 26,2024
making a base for a mini figure and need fine detail for painting it
Hdmi screen from old tablet.
Square holes in PCB. (Or slightly curved edges.)
What is the PCBway company info for the procurement?
Payment methods
@Teslaundmehr I need a EMP Pulse Generator Jammer. Can you build and ship one??
How do I specify slots and holes in the aluminum layer of an aluminum pcb?
Flex PCB Polyimide Coverlay Thickness Availability -- Need Stackup Help
Shipping question
The issue of commission payment when participating in "design sharing."
COMO LEER CHIP
Universal Board
Building ZX80 Replica for Home School STEM Learning
Do you sell this Delta PI Circuit mounted and tested?
Laser Engraving and Silk screening Placement and Files
PCB boards with Wheatstone bridge and BNC output
I need to create a pcb combining an ESP32 with some other components and a display. I also want the plastic design to be created and the electronics installed in it. I am looking for a finished prodct
How much did your stainless steel part cost you
volevo chiedere dove posso trovare il progetto GITHUB della centralina speeduino OPF ECU V0.6 SPEEDUINO MINI PRO? grazie
Washing of PCB Boards after Part Assembly
How to search for a member.
Christian Davies
5
nimalgr
