Do you have a guide for material properties, laser cutting, and bending constraints for 5052 aluminum such as:K factorBend radius (are custom bend radius supported?) Minimum hole sizeMinimum distance ...
Hello Support Team,I noticed that your website features specific PCBs, but I couldn't determine if these are designed specifically for mechanical keyboards. Can you clarify if you sell hot-swappable ...
Hi, I saw that only the Gerber files are available.Your project is really nice and I would like to order by PCBWay some, but without BOM and Pick&Place files are not possible.Is is possible that y...
Well I would like to testing you Layout, but BOM and Pick&Place Files are missing.With only Gerber it is difficult. Wann denkst du das Projekt ganz zu publizieren?Es ist wirklich ein sehr interess...
I find a problem where ordering a simple PCB cost you around 25 USD$ for a start, shipping not included. When ordering PCB it gives you only 2 options for PCB manufacturing times: 24hours with a cost ...
How are threaded holes specified in 3D models? And what file format is best for this. I am just starting to use FreeCad, My part is suitable for CNC turning/machining centre, It's a cuboid with a coup...
