Can I use Petrol clean PCB?
Daveelectronic asked May 11,2018
I was advised to clean PCB using petrol if alcohol is not available. I tested and found that Petrol and alcohol both works good on PCBs. I have also tried with acetone but it makes white spots on PCB.
I just wanted to ask can I use petrol as a PCB cleaner? Or petrol do any adverse effect on PCB?
