Cooling problem---150W boost converter + 100W power LED
Kemio asked Aug 04,2020
I have 12V 10A power supply (PC ) and I use 150W boost converter to raise voltage into 32-35 V (1,5-2A) . I added 15x10cm aluminum plate (5mm thickness , 3 cm fins) to cool LED (thermal paste added).
Is it enough or do I need to add more cooling ? Also 35V 2A causing high frequency buzzing sound .
  • Your Answer(4)
