Line follow
Line-follow
George Kyprianou
asked Jan 18,2019
Need to know more details about this:
https://www.pcbway.com/project/shareproject/Line_Follower.html
What is the dimensions of the board and if possible to buy 2 and what the price is?
Thanks a lot
Line-follow
