Production of the blocked GerberFile
blocked-GerberFile
Alex
asked Apr 20,2019
Hi. Please tell me is it possible to make cost GerberFile-W228920ASU...MANTIS_v1_1.rar
Surface Finish:
HALS with lead
Solder Mask: Red
Silkscreen: White
Thank You
blocked-GerberFile
