I'm new to PCB making for prototyping... I have some old copper clad stock, but its oxidized (salmon color on some and dull finish on others). waht's the best way of removing the oxidation? I read on your blog about using a mouling sanding block. is this similar to what you use for sanding sheetrock? Can you give me a specific example or what grit spec? how about a chemical process like using muriatic acid? which gives the best result (mechanical/abrasive or chemical)?
Thanks,
Rick
1 | PCBWay Team | 10 |
2 | Marcell Feher | 2 |
3 | Engineer | 1 |
4 | Brandon Weatherly | 1 |
5 | Rayan Bayan | 1 |
