Hi!
I have few question abaout ordering. Mostly assembly based.
I want to order 164x10mm PCB with white soldermask, no silkscreen, and with 5 pieces of SK6812RGBW LEDs (SMD5050) and 5 pieces of capacitors (SMD0805 or 0603).
I need 330 pieces of this, doesnt matter if it is on crackable A4 panels or cutted to 330 actual PCB pieces? The PCB calculator is clear, i understand that. About the assebly, it is calculated by pads, so if i have 4 pads on the LED and 2 pads on the capacitor, 5 of each on each PCB, and i need 330 PCB, then it is (4+2)*5*330=9900 pads
. Is it right? And about the parts.
There is customer supply option. So if i buy it on the internet in a
chinese shop, maybe Aliexpress, (im in Hungary), can i send it to you,
and as soon as you receive the parts you start the manufacturing?
And lastly, maybe can you send me a precalculated price on the PCB and assembly with theese parameters. I cannot add the gerbers on this messaging interface.
Regards,
Sandor Ulaki
HarMoZone Kft.
1 | PCBWay Team | 10 |
2 | Marcell Feher | 2 |
3 | Engineer | 1 |
4 | Brandon Weatherly | 1 |
5 | Rayan Bayan | 1 |
