348
[Others]
1850V Cockroft Walton Voltage Multiplier / Bug Zapper Circuit
what is the distance between holes for capacitors?
1850V-Cockroft-Walton-Voltage-Multiplier--Bug-Zap
May 18,2021
Kaushal
Internal Splice Broaching?
