About sensi pot
Assembly
Andrius
asked Mar 10,2020
Hey! Ive just bought sensi pot pcb. I have on question. there is some electronic components list needed in assembly? Thanks for answer!
Assembly
KhronoSound Audio
john James
LouD _
