491
When to use the Autoroute feature in Altium designer ?
When should I choose to use the Autoroute feature in the PCB layout software Altium designer and when should I route by hand? Any experience?
Autoroute-feature
Altium-designer
Sep 11,2020
Bobby Iridium
W37275CCSH52 Ruler
