598
looking for an Arduino shield board template only...
I am looking for a Arduino UNO "BOARD TEMPLATE, for creating my programming shields. How do I get the circuit board designer to shape the Circuit board, so I can put my design on it??Thanks!
Arduino-Shield-Template-for-the-circuit-board-only
Oct 30,2021
Krrish Verma
