494
Can I use a DC sine wave to drive a single phase induction motor?
I wanted to try building a driver circuit for a small induction motor, using an ATMega328P (i.e. the micro in the Arduino UNO) to generate a 5 kHz PWM signal which changes duty cycle every period usin...
ATMega328P
single-phase-induction-motor
DC-sine-wave
Jan 14,2021
Nikola Krneta
