310
Charge battery using EV charger
Hi, I'd like to buy parts to build your Bluetti AC 500 but need help with how to charge it when traveling. Is there a way to charge this from an EV car charger? I don't have solarI...
DIY_EV_charge
Sep 30,2021
Dauk
