DIY universal pcb
Engineer asked Jan 04,2020
Hello.
I need a DIY universal double sided protoboard, (both sides identicle). It needs to be 260mm X 25mm with a 3mm drill hole on each corner. So basically the standard protoboard but the size I require.
Is this possible to do?
If so. How much would it cost including delivery to UK.
Thank you.
  • Your Answer(3)
  • 0
    Hello sir I can make for you the PCB and U can order it from PCBWAY
  • 0
    Hello sir You can directly buy the board from pcbway gift shop which is quite cheaper and the quality is also great. To find the shipping charges for UK , get the quotation on the proceed to checkout page where you can get quotation of 5 courier companies. Which one you need you can get there! For less no. Of days go for DHL or for low cost go for H.K post. Thanks
  • 0
    Sorry, sir. We don't have that size product. We have: https://www.pcbway.com/Project/gifts?toolboxid=0&itemsboxid=0&sortid=0&stock=0&ipuSearch=DIy&isoffset=1
1 PCBWay Team 4
2 Engineer 1
3 Julian E 1
4 Aram Novikov 1
