533
Dielectric Constant for specific Laminate type and thickness
I need to design a board with high speed signals like DDR3. I see that its possible to specify what type of laminate to be used. But when specifying the stack-up and the laminate thickness between sig...
DDR3
Impedance
Dielectric-Constant
Dec 12,2019
Láng Róbertné
