375
ECU MP9.0 memory adapter PLCC32 - M27C512 OTP
This adapter is design for a 87C510 DIP28 eprom, but i need the same adapter for a 87PC110 PCC32 eprom !Do you have this adapter or can you make it ?It's the same converter (74HCT573), with same p...
Eprom-adaptor-87PC110
Oct 05,2020
