970
How to identify sensor if on a pcb
Good dayPlease I want to trace a fault on an S2 Board controlling an NCR S2 machineHow do I identify a sensor ic that control the divert gate sensor on the pcbHow is an ic that controls sensors ...
How-to-identify-a-sensor-ic-on-a-pcb
Jul 14,2021
Ed Ouellette
