How to order 3 different PCBs in a project
Engineer asked Mar 02,2025
Hy all, I have a project with 3 different board per unit.
So in the ordering I can select "Single pieces", it means you will cut the panel.
Then I select 3 "Different design in panel", so in every single panel I should have the 3 PCBs toghether.
Now when I put size, which size I will have to input? the largest PCB? the panel I imagine you will obtain from that?
Finally, regarding "Quantity" what should I select? by default I can select multiple of 5, so if I select 5, what should it mean, 5 in total or 5 for every kind of the 3 PCBs?
Greetings
    1 PCBWay Team 5
    2 Engineer 2
    3 Engineer 1
    4 sheng wang 1
