How to order the PCB from shared project
Engineer asked Feb 04,2021
Hi, I need to know the procedure of ordering the PCB from a shared project [https://www.pcbway.com/project/shareproject/W27592ZSZ14_Surround_Decoder.html] and get it assembled also from PCBWay. How can I order both at the same time and I also want to know that if I do not opt for component assembly, do I get the gerber files and assembly instructions with the PCB so that I can try to assemble components manually. The project page says it has description, technical details and assembly instructions in a zip files, when I order just the PCB print, would I get the files as well.
  • Your Answer(3)
    1 PCBWay Team 5
    2 Engineer 2
    3 Engineer 1
    4 sheng wang 1
