1353
[PCB Assembly] How to order the PCB from shared project
Hi, I need to know the procedure of ordering the PCB from a shared project [https://www.pcbway.com/project/shareproject/W27592ZSZ14_Surround_Decoder.html] and get it assembled also from PCBWay. H...
order-procedure
Assembly
PCB-Print
Feb 05,2021
Sayanik Mandal
