Is the use of a optocoupler good for this application?
Neil Swiff asked Dec 16,2020
There is a power source of 75V and I want my Arduino to acknowledge when a switch has been activated. Such as when a switch closes it can read that it has been closed and perform a certain action. Is the use of a optocoupler good for this since there are no mechanical moving parts thus no possible switch bouncing? Or would it make more sense to use a buck converter to step it down to 5V and just have a SPST and have the Arduino read that instead?
  • Your Answer(2)
  • 0
    if you dont use opto maybe it burns your arduino
  • 1
    Yes, you can use optocoupler to do this, you can use phototransistor output (so open-collector) to drive a digital input (with external pull-up resistor or internal one if available). Buck converter, in my opinion, is worthless solution. Here an example:
1 PCBWay Team 15
2 Malcolm Low 4
3 Engineer 2
4 Engineer 1
5 Engineer 1
6 RODNEY THAYER 1
7 Arno Sommer 1
