Kitting, partial assembly
Engineer asked Jun 10,2020
1. Can I supply for my PCB assembly SMD parts on tapes or
should I order them on Reels before sending to you?
2. For my first prototyping series board I would like to order from
you only assembling SMD parts. The trough hole parts I would
solder myself. Would this save me the cost on the first run?
3. If my protoype boards will not require layout changes, can the
files and stencils be used for volume production?
  • 0
    Hello, 1. It depends on the number of your SMD parts. If you plan to send them in bulk, we suggested you order on reels. 2. Yes, it will save some cost. Because we charge for the number of holes that need to be processed. 3. Yes, you can have “repeat“ orders without changing the files.
1 PCBWay Team 4
2 Engineer 1
3 Julian E 1
4 Aram Novikov 1
