349
Constant current LED driver
I want to power a constant current LED (145mA & 200mA) at 19-21V.Since this will be powered by Li-ion battery connected to a tp4056, which is the most efficient way to boost the voltage from 3.7V ...
Constant-current
Li-ion-battery
LED-driver
Aug 12,2020
Joson
