318
Will my footprint pad spacing add manufacturing cost?
Hello PCB Way Support team, I have been told that having traces or gaps smaller than 6mil will add additional manufacturing cost to a board. On the PCB im working on now, i have a single fotoprint wit...
PCB
Manufacturing-Cost
Minimum-Spacing
Dec 20,2019
Ngwakwe Ifeanyi Victor
