Prepare panel of small board
Dim asked Dec 06,2019
Hello,
I want to send you my design.
My board is 30mmx40mm. I would like to order a panel. What is the standard  suggested panel size where i can utilize the space.
Thank you
Dimitar
  • 0
    That depends on how many PCBs you need in a Panel. Normally the price won't increase for Panel size under 100x100mm. So if you consider that then you can make it a 3x2 panel. then the overall panel size will be 90x80mm. However you can check different parameters for Penalization in PCBway Instant Quote system. You'll get an idea about it.
1 PCBWay Team 5
2 Ondřej Kuběna 2
3 Engineer 1
