Properties For A Two Layer Board
Engineer asked Jul 21,2020
What is the standard stackup for a 1.6mm thick two layer board? I can only seem to find stackups for four layers and up.
Thanks!
  • Your Answer(3)
  • 0
    Hello, You can choose the thicknesses of the board and the weight of the copper . Outer Layer Copper Thickness: 1oz/2oz/3oz(35μm/70μm/105μm) Here is the link for you to check. https://www.pcbway.com/capabilities.html The property of a dielectric which determines the electrostatic energy stored per unite volume for a potential gradient Here is a link for you to refer about the Dielectric constant.. https://en.wikipedia.org/wiki/Relative_permittivity
  • 0
    Hello sir, There is no stackups with Two layer board. And 1.6mm thick two layer board is available.
    Engineer 2020-07-22 01:03:27Reply
    What are the thicknesses of the Dielectric and copper? What is the Dielectric constant? For a two layer 1.6mm board.
1 PCBWay Team 11
2 Engineer 6
3 Arno Sommer 5
4 Engineer 3
5 Curious Scientist 1
