SMT & THT Assembly
Luke asked Oct 18,2021
From what i have read, PCBway support SMT and THT assembly.
Im used to using *** PCB who only support SMT on one side of the board.
I provide *** PCB with the .bom and the .pos + Gerbers and based on the preview i would rotate the components in the .pos file so the components are assembled in the correct orientation. however, it doesnt seem to be the same with PCBway.
Can pcbway confirm whether they accept the .pos file and instead of the customer changing the rotation data, you want the silkscreen on the board to indicate the rotation to indicate where pin one is and the anode and cathode correct?
and im i correct in thining pcb way will assemble both top and bottom layers with both THT and SMD components? or are their constraints as to what is assembled?
  • Your Answer(3)
    1 PCBWay Team 11
    2 KhronoSound Audio 2
    3 john James 1
    4 Engineer 1
    5 LouD _ 1
