353
T-Clad (Thermal Clad) versus FR-4 COST
What is the cost difference between Thermal Clad aluminum (LED circuit board type) substrate compared to FR-4 board per square inch. For a 1 layer board. 1.65 mm thickness. Both mate...
T-Clad-Aluminum-versus-FR-4-Substrate
Dec 14,2020
