462
200Watt amplifier TDA7294
Hello,I have download files for that amplifier TDA7294. Board is beautifull designed.Please can you help me with holes for TDA7294? holes needs to be bigger 0,2mm on diameter. TDA doesn t fit ot...
TDA7294-placement
Jan 14,2020
Brijesh Kumar
