358
Parts required for BE6502 Build a 6502 computer (SBC-module revision A)
Hello:I've just received the PCBs from the BE6502 Build a 6502 computer (SBC-module revision A) project created by Tor-Eirik Bakke Lunde. It is nicely laid out. I have a couple of quest...
Tor-Eirik-Bakke-Lunde
Mar 12,2020
W37275CCSH52 Ruler
