293
Still producing the IMST iC880a backplane?
Hi,Just wondering if you are still able to produce the above backplane from the W28184AXM5_ic880a-rpi-backplane-rev-v1.2.zip file?If you are and just so I understand correctly, is it $45 dollars ...
Aug 17,2021
