481
W59251ASP4_Plata2
Hi,I bought 10 pieces of W59251ASP4_Plata2 pcb. However this pcb is not working properly. May you please send me the schema of it to oguzkaraoglan@gmail.com.Thank you.
W59251ASP4_Plata2
Sep 29,2019
Praddy
