318
Is it possible to exceed inputs whilst keeping concurrency?
I'm building something with an arduino nano which uses 8 buttons (digital) and 8 potentiometers (analog). I would like to add more inputs to the build, but need to be able to use multiple inputs a...
arduino-nano
Dec 01,2020
myth318
463
MPCNC-Nano-Estlcam-Shield - Electronic components
Hello,you can also supply the components for the PCBMPCNC-Nano-Estlcam-Shield?Sincerely, S. Knobloch, Germany
mccnc
arduino-nano
estlcam
Dec 17,2019
