6
389
Why do audio amplifier have volume control and not gain control?
It is always seen that audio amplifier work at fixed gain, while attenuating the signal at the input to change the volume. That doesn't sound good since you decrease signal to noise ratio. Also re...
at-fixed-gain
volume-control
audio-amplifier
Dec 08,2020
Paul H
