534
Can I put mount holes on edge cuts layer?
Can I put 3mm and 4mm holes on the edge cuts layer or do they need to be called out in the drill files?
board-outline
edge-cuts
mounting-holes
Oct 29,2021
Michele Bertoni
W37275CCSH52 Ruler
