kv4p HT v1.5
kv4p HT v1.5
can I have a via in a pad
asked Oct 20,2024
Can I have a via from the back to the front where there is an ic pad.
2525 (QEEV Series) 1KV capacitors
Arduino project
Its simply voltage devider for esp32 to sense 18650 battery, n mosfet to reduce power consumption, im sitting all night tonigh on it . Is this schematic correct please
i want to make a metal detector but dont know wich circuit to use i found oscilator circuits but idk if they are good can som1 pls help me with a good circuit
Where can I get impedance tuning values for a 4 layer board?
MultiROM Cartridge for Timex Computer 2068
How Can I use my Beans ?
How can I combine several PCB projects in one order and how to price them?
PCB for a Portable Bluetooth Speaker Using the BT4840 Module
100ohm impedance 4-layer flexible PCB design
how to import gerber file in eagle version 7 ? thanks
3D printable plastic shell
Asking about generating gerber files by using Orcad X Presto
Can I send in a PCB to get replicated/reverse engineered?
profide the full bom ?
Need information on you Servo Board.
how do I order this project
PICOZX motherboard with keyboard for ZX Spectrum original case or standalone
How do I make a solder mask with Solidworks PCB?
Ross Feng
